Frag Tank Pics/Specs
Discussion on breeding & propagating marine fish, corals & other species.
Moderators: Moderators, Mod: Propagation & Breeding
Postby hellaflush » Sat 30 May, 2009 12:39 pm
post em up guys...
coral propagation is a fantastic thing... to not only minimise the expense of this hobby but also to assist with the depleting colonies in our oceans :cheers:
i will be building mine shortly!
would just like to see how some aussies do it compared to RC/3reef etc
Tank Dimensions
Lighting
Sump
Dosing
and most importantly... PICS!
Adz
R.I.P Pacman
hellaflush
Postby KirTracid » Sun 31 May, 2009 9:13 pm
Mine's nothing special. It was originally intended to be a temporary home, well 3-4 months later it's finally being pulled down =)
It's a 3x2x2, soon to become a 3x1.5x1 (the lower the better I say)
I want to eventually seperate my LPS/softies from the SPS so I can emulate their conditions better.
My tank is half display/half frag tank, as I needed somewhere to keep my stock. Frag racks were designed with a pvc skeleton with eggcrate cable tied on.
My sump is a 50 litres $10 container. Inside that is another container which contains my DSB.
Light is 4x39w t5 (good bulbs ONLY)
Dosing is via 2 part.
I thought I had a FTS in my journal, but I can't find a recent one. It's basically a frag rack, with a heap of SPS in the other 1.5 foot of tank space =)
-Kirsty
My new 10x3.5x2 SPS dominated mixed reef ( start date: Christmas time)
My 5x2x2 SPS dominated, ATI LED Powered ZEOvit Reef - basically discountinued
Where clams & Angelfish can live in Harmony :)
KirTracid
Postby KirTracid » Mon 01 Jun, 2009 11:27 am
It's not much, but here's the FTS I said I'd find yesterday for you to have a look at. I don't advise doing things like this, but I was just working within my constriants as I was only intending to have this up temporarily
Just so you can see the basic layout of a split setup (not my advice, but certain corals do better in certain place, eg. The tub of sand in the bottom holding the trachy and cat)
<a href="http://s451.photobucket.com/albums/qq239/KirTracid/?action=view&current=DSC_0142.jpg" target="_blank"><img src="http://i451.photobucket.com/albums/qq239/KirTracid/DSC_0142.jpg" border="0" alt="Photobucket"></a>
-Kirsty
KirTracid
Postby Stormtrooper » Wed 03 Jun, 2009 11:51 pm
Stormtrooper
Postby glennb » Thu 04 Jun, 2009 12:51 am
Probably not much to be derived from my experiences because the setups were haphazard - plumbed into the display and pieced together from whatever tanks, pumps, and lights were on hand at the time. These were usually bare bottom skimmerless sytems with relatively high flow rates. Watt for watt, growth was typically faster with 10k 150w MHs than bluish T5s.
-Glenn
glennb
Postby MattRichards » Thu 04 Jun, 2009 2:12 am
Shallow and wide to maximise propagation area.
Bench top height for easy access and rounded corners helps with current.
MattRichards
Postby hellaflush » Thu 04 Jun, 2009 2:15 am
glennb... i see you have a bit of an acan collection... i think some trading is in order once im up and running!
Adz
R.I.P Pacman
hellaflush
Postby glennb » Thu 04 Jun, 2009 12:23 pm
Adz, that was an old photo, all the acans were moved on
Matt, those lighting hoods are huge. Is that because you run one lamp per tank? And what lamps do you use?
-Glenn
glennb
Postby MattRichards » Thu 04 Jun, 2009 11:52 pm
glennb wrote:Matt, those lighting hoods are huge. Is that because you run one lamp per tank? And what lamps do you use?
Yeah one lamp per hood, though there is room for more if wanted.
I use either 250 watt MH or 400 watt MH.
I got them cheap, but since then I've swaped them for smaller ones,
they were getting in the way making it difficult to lean over the pond.
MattRichards
Return to Propagation & Breeding
Users browsing this forum: No registered users and 9 guests
