100% Reef Safe Amino Acid Protein Supplement
This forum is run by 100% Reef Safe (a MASA Business Partner). Use this forum to discuss any related topics about 100% Reef Safe products, sales or any general questions you would like us to answer.
Postby 100% Reef Safe » Sat 24 Jan, 2009 3:21 pm
After alot of research we are happy to offer the 100% Reef Safe Amino Acid Supplement to you. It has been well recieved by fellow reefers here in Qld. :thumbsup:
Here is a link to the web site 100% Reef Safe Amino Acid Supplement
Amino Acid Protein Supplement For Marine Tanks
Facilitating optimum nutritional uptake of beneficial algae
This supplement will maximise coral growth, colour and polyp extension. It will enhance the healing process in damaged corals and encourages the production of more protective slime in SPS corals.
Amino Acids are fast becoming one of the most essential additions to any serious reef keeper’s arsenal. There are many different reasons why they are being used. Vitamins and proteins are included in one easy supplement to provide your corals with the much needed energy that they would not otherwise get in a closed aquarium environment.
In Nature, corals will receive these proteins via plankton, micro plankton or even bacterial plankton. However in a closed aquarium environment these are normally not present. Zooxanthellae which live symbiotically in many corals “expel” these acids which in turn feed the coral along with many other substances. In most aquariums the activity of these symbiotic algaes are greatly reduced in which the corals are only “Surviving” and not “Thriving”.
Indirect and Direct feeding’s are generally not the best method to approach feeding your corals as it generally results in increased nutrient levels such as phosphates and nitrates. This is where the Amino Acids come in handy. By dosing high quality products such as 100% Reef Safe Amino Acid Protein Supplement, you are introducing the correct proportions of amino acids found in coral skeletons. This then helps to create the conditions found in a wild living coral reef.
Recommended Dosage:
½ to 1 level scoop (enclosed) per 500lt of aquarium water. Mix the required amount of Amino Acid Protein Supplement in a container, let stand for 1 hour then slowly add to the aquarium.
Contains:
Alanine, Arginine, Aspartate, Cystine, Glutamate, Glycine, Isoleucine, Leucine, Valine, Tryptophan, Lysine, Methionine, Histidine, Proline, Serine, Tryosine, Phenylalanine, Threonine. No Preservatives - does not contain Phosphate based preservative.
Given this is a protein product your skimmer may produce excessive skimate with the addition of this supplement to your tank.
NOT FOR HUMAN CONSUMPTION
STORE IN A COOL DRY PLACE
Net Weight 50gms
Contents may settle after packaging
Pete
100% Reef Safe
MASA Partner
MASQ Supporter
Re: 100% Reef Safe Amino Acid Protein Supplement
Postby 100% Reef Safe » Thu 02 Sep, 2010 9:55 am
I have been having a few enquiries whether or not it is available and i just want to let everyone know that it is always in stock :thumbsup:
Pete
100% Reef Safe
MASA Partner
MASQ Supporter
Postby 100% Reef Safe » Thu 02 Sep, 2010 12:09 pm
Forgot to add it is only $15 plus $5 postage to anywhere in Australia :thumbsup:
100% Reef Safe
MASA Partner
MASQ Supporter
Postby 100% Reef Safe » Mon 06 Dec, 2010 12:28 pm
A great article on the benefits of using Amino Acids
Amino Acids
Pete
100% Reef Safe
MASA Partner
MASQ Supporter
Postby Lukey » Mon 06 Dec, 2010 5:49 pm
How many scoops per bag thingo mr Pete?
p.s, Site is mega b0rked?
edit: I'm a little slow lol, soz :p
All good Luke
About 3 months worth i would imagine but each user is different. :thumbsup:
Lukey
Postby Postal » Thu 28 Apr, 2011 10:50 am
While many have questioned and pondered the mysterious source of the Amino Acids I though I would take the plunge and purchase some and see how they go.
Firstly my tank has always had low nutrients, this is because of low stock (not many fish), small feedings (for my small amount of fish) and a large skimmer, also I occasionally spill vodka in the tank which seems to help.
Tank Stats:
4x2x2 + sump approx 500L total volume
Nitrate: 0
Nitrite: 0
Alk: 8
Calcium: 410
Phosphate: 0.00 (hanna meter)
This is a small tabling acro I got from 100% Reef Safe
This is it about ~2 months later
Excuse the bad photos the glass was very dirty. So this acro had pretty good growth and had turned a sort of rusty orange/brown color.
This is 1 week later after dosing AA's every second day with the skimmer turned off for 1hr. I use the Tropic Marin phyton/zooton (coral food also available from 100% Reef Safe) spoon and just add 1 spoonful.
Basically what has happened is within a week the new growth on the acro turned pink and it has now started to work down the body of the acro.
My tank levels are the same as when I started, but my acro is coloring up nicely and I couldn't be happier with the result :bow: In regards to how long it will last, well at my current dosing I would estimate 2 years which isn't bad for $15 I may step up the dosing level in the future but things seem to work nicely for now.
I will add some more pics as the acro keeps coloring up, but I would recommend this to anyone who likes the colorful sticks :cheers:
Postal
Postby 100% Reef Safe » Tue 03 May, 2011 12:40 pm
Thanks Zeke :clap: :clap:
That is a great turnaround in the coral.
Pete
100% Reef Safe
MASA Partner
MASQ Supporter
Postby holla_passer » Sat 20 Aug, 2011 4:10 pm
Is there any risk with over-dosing amino acids?
holla_passer
Postby 100% Reef Safe » Sat 20 Aug, 2011 4:15 pm
holla_passer wrote:Is there any risk with over-dosing amino acids?
No, as any excess will be skimed out. I have dosed with double even triple the amount with no side effects. :thumbsup:
100% Reef Safe
MASA Partner
MASQ Supporter
Postby holla_passer » Sat 20 Aug, 2011 4:23 pm
Thanks for the quick reply Pete! I don't actually run a skimmer on my nano so that would be a problem wouldn't it?
By the way, received the AA from you yesterday, thanks for that mate...very quick delivery!
holla_passer
Postby 100% Reef Safe » Sat 20 Aug, 2011 9:39 pm
holla_passer wrote:Thanks for the quick reply Pete! I don't actually run a skimmer on my nano so that would be a problem wouldn't it?
I would reduce the dose a bit and see how it goes. I am pretty confident it wont be a problem as it would be taken up by the corals fairly well.
Pete
100% Reef Safe
MASA Partner
MASQ Supporter
Postby hypernatremia » Tue 13 Sep, 2011 11:22 pm
Hi Pete,
Just curious if you know the reason why the amino acids have to stand for an hour before going into the tank. Are there any adverse effects if I don't wait that long?
hypernatremia
Postby 100% Reef Safe » Wed 14 Sep, 2011 10:17 am
hypernatremia wrote:Hi Pete,
Only reason is to absorb into other products if used in conjunction to amino acids like phyton, zooton, reefroids etc to help boost these foods. Other than that it can be dosed after mixing. :thumbsup:
Pete
100% Reef Safe
MASA Partner
MASQ Supporter
Postby skud » Sat 17 Sep, 2011 9:24 pm
Hi pete, can I mix the amino acid together with the reef roids and dose at the same time? how often should I be dosing ?
Thanks skud :thumbsup:
skud
Images: 17
Postby n0rk » Sat 17 Sep, 2011 9:38 pm
You can and should mix it with foods :) start off 1-2 times a week at a smaller dose rate, then gradually build up. At smaller rates I was able to dose it daily, though most tanks will be fine 2-3 times a week.
Postby 100% Reef Safe » Sat 17 Sep, 2011 10:50 pm
skud wrote:Hi pete, can I mix the amino acid together with the reef roids and dose at the same time? how often should I be dosing ?
Yes you can and build it up to everyday. I think Ben has pretty well hit the nail on the head.
Pete
100% Reef Safe
MASA Partner
MASQ Supporter
Postby mattgreen » Tue 11 Oct, 2011 12:40 pm
just ordered some lets see how lps reacts
mattgreen
Postby pleco4me » Fri 02 Nov, 2012 3:04 am
Hi Pete
Is this suitable to use with the zeovit system?
Craig
pleco4me
Postby 100% Reef Safe » Sat 03 Nov, 2012 11:40 pm
pleco4me wrote:Hi Pete
Craig
Hi Craig,
I haven't had anyone tell me they have used it on a full Zeovit system but many have on partial systems without any issues at all. Maybe one of the Zeo users who has used it could comment. I can't see it having any adverse affects on it though.
Pete
100% Reef Safe
MASA Partner
MASQ Supporter
Postby baker_gt » Wed 28 Nov, 2012 10:44 pm
Silly question, can this be used to gut load brine shrimp and rotifers?
baker_gt
Postby 100% Reef Safe » Thu 29 Nov, 2012 2:25 pm
baker_gt wrote:Silly question, can this be used to gut load brine shrimp and rotifers?
From a nutitional value they would benefit from it yes, but i would probably start with a 1/4 dose initially and see how they go. Personally i have never tested it for this purpose.
Pete
100% Reef Safe
MASA Partner
MASQ Supporter
Postby baker_gt » Thu 29 Nov, 2012 4:07 pm
1/4 dose? a standard dose is 1/2 -1 spoon. What would a 1/4 dose be for 250ML of BBS?
What would be better to enrich these little guys?
baker_gt
Postby 100% Reef Safe » Fri 30 Nov, 2012 1:38 pm
baker_gt wrote:1/4 dose? a standard dose is 1/2 -1 spoon. What would a 1/4 dose be for 250ML of BBS?
I assume you are using it on your tank? If so i would take a little once mixed and add that to your BBS.
Pete
100% Reef Safe
MASA Partner
MASQ Supporter
Postby baker_gt » Fri 30 Nov, 2012 8:07 pm
Ah sorry, im using these lives foods for baby clowns. Just trying to give them the best chances of life!
baker_gt
Postby 100% Reef Safe » Sat 01 Dec, 2012 12:39 am
Ah ok
100% Reef Safe
MASA Partner
MASQ Supporter
Postby Riaan_Tas » Thu 10 Jan, 2013 5:01 pm
Hi there
Just need some advice on the amino acids .... Can it be setup mixed in say 500 ml container and then dosed 3 ml a day for 700L tank ... if so mixed with reef roids ... can this be done and what steps would be needed to keep the mixture "fresh"
Sorry for all the questions but still learning ...
Riaan_Tas
Postby 100% Reef Safe » Fri 11 Jan, 2013 4:20 pm
Riaan_Tas wrote:Hi there
Unfortunately no it can't be done this way as it is a protien and will go off. The longest i had it set up like this was 3 days up here in Qld but it was the heat that got to it. Even coral foods will go off once mixed with water after a few days. Some people have made a batch enough for a weeks worth and kept it in the fridge and dosed as needed through out the day over the week.
Pete
100% Reef Safe
MASA Partner
MASQ Supporter
Postby fezzz » Tue 09 Apr, 2013 9:50 am
do you dose the amino acids mixed with reef roids during the day or at night? im thinking just as the sunset is finishing up.
fezzz
Images: 44
Postby peekandboo » Tue 09 Apr, 2013 6:03 pm
fezzz wrote:do you dose the amino acids mixed with reef roids during the day or at night? im thinking just as the sunset is finishing up.
I mix mine with ether reefpearls, reef roids or tropic Marin photo/zoo and dose during when lights on one day then next day feed when lights off as some corals feed during lights on and off.
HTH
peekandboo
Postby fezzz » Wed 10 Apr, 2013 9:27 am
do you turn off your return pump and skimmer for half an hour or so when feeding this mixture? and leave vortech on to blow the mixture around the tank? or do you target feed
fezzz
Images: 44
Return to 100% Reef Safe
