TOTM March winner
TOTM March winner
Postby davez104 » Wed 27 Apr, 2011 12:01 pm
The winner of the March 2011 TOTM competition is:
Chris and Lorna aka kipper31 with his beautiful mixed reef system.
Kindly donated by:
Aquablue Distribution
Chris and Lorna have won:
$100 in Ocean Nutrition Foods
You can find out more about the winning tank tank in this Tank Journal
Reason: To fix winning month.
davez104
Re: TOTM March winner
Postby davez104 » Wed 27 Apr, 2011 12:09 pm
Congratulations to Chris and Lorna Heidenreich on winning the RTAW Tank of the Month for March, 2011, with their beautiful, flourishing mixed reef system.
Chris is known as kipper31 on the RTAW forums and you can find out more about this system by checking out his tank journal.
Thanks for choosing our tank for TOTM, my wife and I feel very privileged that other people have found our tank worthy of mention, let alone Tank of the Month.
I have always kept fish of some description as a kid, keeping anything from yabbies and mosquito fish caught in the local creek to Goldfish. I got seriously into keeping aquariums when I met my wife ten years ago, she had a 4ft tank with tropical fish and plants. A few years later we decided to buy a 5ft, all in one tank, and built that up over a few years. We enjoyed an assortment of fish but really liked the look of the planted tanks. We then decided to try a full on planted tank and started researching systems on the net. That's when we stumbled upon the feature tank page on the MASA site. We spent all night looking at journals and pictures and we both knew from that night on that we were going to attempt to keep a coral reef aquarium. We spent probably 4 months researching the net and visiting the local fish stores before we walked into Marine+ in Adelaide and placed an order for the tank and equipment. The tank was finally wet on 22nd of October, 2009.
The tank we chose was 5ft x 20 x 24 inches with a centre weir housing a durso overflow and the return pipes. We kept the custom built, 2 pac painted stand and had the tank built to suit. The only regret we have so far is that we only have a 20 inch wide tank to play with, we know better for the next setup.
Our filtration consists of a 900 x 400 x 400mm sump, divided into three sections. The first houses a Reef Octopus skimmer rated to 1500 litres. The second has a deep sand bed with macro algae grown in about one quarter of the bed. The third section houses the Eheim 5000 compact return pump and a fluid bed filter in which we run Rowaphos to help with phosphate control.
In tank flow consists of two return pipes angled at 45 degrees and two Tunze pumps in each rear corner, so flow is running in roughly a figure eight around the tank. Total in tank flow is approximately 12000 litres/hour, which by some standards is not enough, but at the moment it seems to be working alright.As we move towards a more SPS based tank we might have to add a bit more.
Our lights consist of 2 x 250W, double ended metal halides running AMD 15000K globes and 4 x T5s, 2 of which are ATI aquablue specials, 1 x blueplus and 1 x purpleplus. The lighting period is T5s - 11:30am till 8:30pm, Halides - 1:30pm to 6:00pm.
This Summer we purchased a Hailea 500 chiller and we use an Eden 2400 litre/hour pump to feed water to it. It seems to work well and drops the temperature from27 to 26 degrees in around 15 - 20 minutes, depending on room temperature.
This April we had a trip planned to Cairns and as I had been dosing my supplements manually, I purchased a Bubble Magus dosing pump. With this we dose calcium chloride, magnesium and bicarb soda. I now mix my additives once a week and add it to my auto topup but still keep an eye on the levels as it relies on equal amounts of evaporation each day.
I check my mag and calcium once a week and my alk about twice a week. My parameters are as follows:
Alk - 8.0dKh - API kit
Magnesium - 1350ppm - Salifert kit
Calcium - 400ppm - API kit
Ph - 8.2
Nitrate - undetectable on API kit
Phosphate - I get checked at the LFS and generally comes in at around 0.03-0.07ppm.
We do weekly water changes of approximately 15-20% using RO-DI (PSI unit) and Red Sea Coral Pro salt. Without fail I feel that this is one of the best things I can do for my reef, nice clean water with all the nutrients and at this stage I don't dose anything else. I siphon out any detritus in the sump and then fan the rocks with a spatula before using the siphon etc.
Now for the livestock. we started with a 20kg box of live rock and have added approximately 40-60 kgs of base rock over the last few years, adding bits when we needed more space to mount corals. Fish wise we haven't got a lot as we have mainly been concentrating on the corals. We are now in the process of slowly changing over to a more SPS oriented system.
Fish:
1 Yellow Tang
1 Powder Brown Tang
2 Banggai Cardinals
1 Lawnmower Blenny
1 Damsel that basically rules the tank
Corals:
Favites/Favias
Trachyphyllia
Cataphyllia
Acans of assorted colours
Blastomussia red/green and green/blue
Zoas
Lobophyllias
Montipora
Seriatopora pink Birdsnest
Turbinaria
Acropora/Millipora
assorted Mushrooms
Finally I would like to thank all the guys on MASA that have helped me along the way and especially the guys at Marine Plus who i have purchased most of my equipment and livestock from. I think they got sick of me asking questions at the start but I gather they get that all the time.
My wife once made this comment when out to tea with half a dozen friends which pretty much sums up my interest in the tank:
"If he had his hands on me as much as he had them in the tank, I'd be a very happy woman"
I think most of us can relate to that comment, being involved in this hobby.
Thanks again.
davez104
Postby reefsecretsaquariums » Wed 27 Apr, 2011 4:54 pm
nice tank mate .. looks good.. :thumbsup:
REEF SECRETS AQUARIUMS (07) 55356996
unit 2 number 9 Kortum Drive, Burleigh Heads . darren@reefsecrets.com.au
Reef Secrets Facebook Page
http://www.reefsecrets.com.au/
Australian Reefing Connection
EMAIL ME INSTEAD OF PMs IT FILLS UP TO QUICKLY. I CAN CHECK EMAILS FASTER.
I DONT WORK ON MONDAYS >>> ITS MY ONLY DAY OFF .
MASA Partner
MASQ Supporter
Postby Flipper » Wed 27 Apr, 2011 5:25 pm
Well done Kipper. Looks great. Good to see you doing us MASAOG members proud :clap:
Flippers Tank Journal
Quietly going about my business
Flipper
Postby Rod the Reefer » Wed 27 Apr, 2011 7:23 pm
Onya Chris. :clap: :clap:
Well deserved win. Yoo Hoo Another MASAOG winner!!(Pity you're talking about pulling it down.)
Postby Eclip » Wed 27 Apr, 2011 8:13 pm
See all that was needed is jessys good camera skills to get this one on top. Top job mate well deserved
MASAOG COMMITTEE MEMBER 2012
Eclip's Sumpless CLOSED DOWN
70L DIY led powered nano
Eclip
Postby camo1 » Wed 27 Apr, 2011 8:35 pm
:clap: :clap: :clap: :clap: :clap:
camo1
Postby kipper31 » Wed 27 Apr, 2011 10:27 pm
Thanks Guys i couldnt have done it without the help from most of the guys on here.Im not pulling this one down im just setting up a pure SPS tank 4x2x2 where i had my Cichlid tank.Ive pretty well got this tank to run itself now, mix chemicals once a week and hardly any maintence so the next project must commence. Ive seen a few photos on Reef central that i realy like, Its montis and tableing type Acros and corlaine covered rock.Thanks Again :cheers:
kipper31
Postby Thommo01 » Wed 27 Apr, 2011 11:39 pm
Congrats Chris and Lorna :clap: :clap: :worship:
We all know the only reason that you are starting another tank is because you have run out of room :roflmao:
Nice pics :wink:
I think the next big purchase should be a camera so you can show the world how nice a tank you have.
Postby shannonpayne86 » Thu 28 Apr, 2011 11:18 am
WOW guys congrats looks awesome!
shannonpayne86
Postby terrar » Thu 28 Apr, 2011 11:59 am
Great tank and certainly an inspiration to me. I am about to build a 4 x 2 x 2 after being tankless for the last 12 months. Can i ask if you are happy with the skimmer you are using? SO many people have different opinions, but i belive a succesful tank is a good indication of what works. Andrew
terrar
Images: 36
Postby teagleton » Thu 28 Apr, 2011 4:15 pm
tank looks sensational mate well done :clap:
teagleton
Postby fishlover » Thu 28 Apr, 2011 8:12 pm
Well done Chris,see I told you all those months ago it was worthy of TOTM.Now bring on TOTY.
Kean
fishlover
Postby RedLineR » Sat 30 Apr, 2011 1:00 am
Congrats :clap: :clap:
RedLineR
Postby Scutzy » Sat 30 Apr, 2011 7:37 pm
That is an awesome tank - huge inspiration to me just starting out, thanks great job :clap:
Some people dream of worthy accomplishments while others stay awake and create them!!
Scutzy
Images: 21
Postby oldsalty » Sun 01 May, 2011 6:54 pm
Great acheivement and a well deservered TOTM
Regards
Winston
oldsalty
Postby terbit » Sun 01 May, 2011 8:26 pm
Congrats Kipper great looking tank :thumbsup:
terbit
Postby pafc64 » Mon 02 May, 2011 5:23 pm
Well deserved winner :clap:
The tank looks even better when you see it for real :clap:
Rick
Rick
Ricks 4x2x2
pafc64
Postby Tom the Reefer » Wed 04 May, 2011 10:08 am
:clap: :clap: :clap: wow :clap: :clap: :clap:
Tom
Have a great day
My 1000ltr LED Beauty
Tom the Reefer
Postby gavogr » Sun 08 May, 2011 8:21 pm
Well done Tank is looking Great,
Might have to pinch a few frags :thumbsup:
Keep it up.
gavogr
Postby Jesster » Tue 17 May, 2011 9:30 pm
well done kipper! love those photos :wink:
Jesse
Jesster
