Tank of the Year Rules
Postby MASA » Thu 14 Apr, 2011 6:40 pm
RULES
Rules and Guidelines for the Tank of the Month (TOTM) Competition
In order to be eligible for nomination into the TOTM competition you must;
1. You must be a member of a MASx group.
2. Your tank must be at least 6 months old.
3. You must have an active Tank Journal in the appropriate area of the forum. Your most recent tank shots for nomination must not be older than 3 months old and must closely reflect the current condition of your tank.
4. Tanks that have already won in the current calendar year (Jan-Dec) are not eligible for nomination. Persons who have won within the past 6 months (even if it was last year) are not eligible for nomination.
For example:
Winner in January 2009 is not eligible for nomination until Jan 2010.
Winner in July 2009 is not eligible for nomination until Jan 2010.
Winner in Sep 2009 is not eligible for nomination until April 2010.
Winner in Dec 2009 is not eligible for nomination until July 2010.
5. Tanks that have been shutdown, crashed, sold or have been significantly changed since the last photo updates are not eligible for nomination of TOTM.
6. In the event that you are chosen as the TOTM you must be able to supply recent photos (less than 1 month old) of your tank for use in your tank write up, and consent to the use of the photos on the MASA website and/or forums. If you are unable to supply photos you will forfeit winning and the TOTM will be awarded to the runner up.
7. All TOTM winners are eligible for TOTY, even if the tank has crashed, changed or shutdown.
Marine Aquarium Societies of Australia :
MASAOG, MASOV, MASRQ, MASQ, MASS & MASWA
MASA
