Welcome to the tank journal thread (inc template)
Postby MASA » Wed 13 Apr, 2011 6:33 pm
Each user is permitted to start one post regarding their tank, which they may update as often as they wish. Anyone may respond with questions, comments and constructive suggestions. The moderators will prune out any off topic chit chat that may occur, simply to make it easier for all members to browse through the forum, and get as much information as easily as possible.
If you wish to search for a particular users thread, simply search this forum only, with the search parameter being the users name whos tank you wish to read about, and you will easily find it.
If you have any questions about the use of this forum etc, please ask in this thread, in order to keep the forum as usefull and easily searchable as possible.
Posting pictures
Tips for taking full tank shots.
Marine Aquarium Societies of Australia :
MASAOG, MASOV, MASRQ, MASQ, MASS & MASWA
MASA
Re: Welcome to the tank journal thread (inc template)
Postby MASA » Wed 13 Apr, 2011 6:34 pm
Just a little something to assist people to get their journal under way. Will also give those reading the journals some consistency as they go through them. Please note this is in no way compulsory, just a helping / guiding hand. Feel free to add it retrospectively if you have a journal running.
Copy the code between the {code} thingy's and paste it into your first post of the journal, modify to suit :thumbsup:
Code: Select all
[color=blue][b]Introduction:[/b][/color]
Add your intro here
[b]System Objectives:[/b] What is the end result going to be?
[b]System Type:[/b] Fish only, FOWLR, Predator, SPS, Mixed Reef, Softies only, Non photosythetic Corals?
[color=blue][b]Display System:[/b][/color]
[b]Strike up Date:[/b] Date system started
[b]Display Tank:[/b] Display tank specifications.
[b]Display Lighting:[/b] Lighting specifications.
[b]Stand:[/b] Stand specifications.
[b]Hood:[/b]  Hood specifications.
[b]Sump:[/b] Sump specs if applicable.
[b]Refugium:[/b] Refugium Specifications if applicable.
[b]Refugium Lighting:[/b] Lighting specifications.
[color=blue][b]Support systems:[/b][/color]
[b]System Water:[/b] Natural salt water or artificial salt water
[b]Display Water circulation:[/b] In tank water circulation.
[b]Return Pump:[/b]Sump return pump.
[b]Skimmer:[/b] We all got one do you?
[b]Evaporation Top Up:[/b]Auto topup or manual?
[color=blue][b]Chemical Support:[/b][/color]
[b]Calcium Addition:[/b] If not calcium reactor
[b]Alkilinity Addition:[/b] If not calcium reactor
[b]Other Chemical Maintenance:[/b] Magnesium etc
[b]Current Water Chemistry:[/b] If applicable
[b]Nitrates:[/b]
[b]Phosphates:[/b]
[b]Alkalinity:[/b]
[b]Calcium:[/b]
[b]Salinity / Specific Gravity:[/b]
[b]Magnesuim:[/b]
[color=blue][b]Images:[/b][/color]
You dont need to add the banana :poke:
It will look something like this:
Add your intro here
System Objectives: What is the end result going to be?
System Type: Fish only, FOWLR, Predator, SPS, Mixed Reef?
Strike up Date: Date system started
Display Tank: Display tank specifications.
Display Lighting: Lighting specifications.
Stand: Stand specifications.
Hood: Hood specifications.
Sump: Sump specs if applicable.
Refugium: Refugium Specifications if applicable.
Refugium Lighting: Lighting specifications.
System Water: Natural salt water or artificial salt water
Display Water circulation: In tank water circulation.
Return Pump:Sump return pump.
Skimmer: We all got one do you?
Evaporation Top Up:Auto topup or manual?
Calcium Addition: If not calcium reactor
Alkilinity Addition: If not calcium reactor
MASA
Postby Aronnax » Wed 06 Feb, 2013 8:47 am
MASA wrote:...We would like to encourage all users of this forum to put their aquarium, livestock and equipment details into the registries in MyMASA. This will not only provide you with an easy picture hosting solution, but will help to add to the invaluable resource contained with the MASA registries...
Posting pictures
I'm new to RTAW and am setting up my Tank Journal. you mention placing all the aquarium livesock and equipment details in the registries in MyMASA. When it comes to forums and the like I'm not the sharpest tool in the shed :stupid:
so if you can give me some instruction on how to do this it would be appreciated
Stuart
Click to Join the Marine Aquarium Society Of Victoria Today!!
"Don't raise your voice, improve your argument" - Desmond Tutu
Aronnax
Images: 22
Postby marks » Wed 06 Feb, 2013 8:52 am
Hi MyMASA is no longer available.
Someone needs to fix that up.
Mark
marks
Postby Aronnax » Wed 06 Feb, 2013 9:02 am
thanks for the prompt reply.
I don't feel quite so dumb now that I know there's a good reason I couldn't find it.
Stuart
Aronnax
Images: 22
Postby JacP » Sat 06 May, 2017 12:53 pm
Hi, I am Jacques, Jac will do just fine. I had an 8ft 500 gal marine tank, set up in 1990 and maintained for 20 years while living in Asia.
We have settled back into life in Oz, and are just about to pour the slab on an extension to the house. This will be a large room, lounge and dining, with pride of place being the new Aquarium as the divider.
System Objectives: A full reef tank, that can be maintained well, despite 3 young kids.
Strike up Date: TBA
Display Tank: 2800L x 1100W x 850 H
Display Lighting: T5 HO and LEDs
Stand: Steel, powder coated
Hood: full hood, on ceiling mounted actuator to rise 60 cm for access
Sump: Located in the basement, 12 meters away and 1 fllor down. Size approx. 2000L x 750W x 500H
Refugium: TBA
Refugium Lighting:TBA
Display Water circulation: Closed Loop
Return Pump:TBA
Skimmer: JNS
Calcium Addition: TBA
Alkilinity Addition: TBA
Current Water Chemistry: 0
JacP
