ROYAL EXCLUSIV this WEEKS SPECIALS
This forum is run by Aquabella Aquariums (a MASA Business Partner). Please feel free to use this forum to discuss any topics about products, sales or any general questions you would like us to answer.
Postby AQUABELLA » Thu 17 Jul, 2014 10:40 pm
laybuys are welcome
Return pump Red Dragon rd3 Speedy 80 Watt
ENDED
http://royalexclusiv.net/Flow-Pumps/Sal ... :1301.html
Bubble King Double Cone 150
ended
http://royalexclusiv.net/Skimmer-Pumps/ ... 0::68.html
for aquariums up to 350 liter
hard facts Bubble King® Double Cone 150:
625 l/h Air - 800 l/h Water = 1 Pump MRD 600
Base plate: 19,5 cm x 24,5 cm / height ~ 50 cm
Technical data Bubble King® Double Cone 150:
Skimmer-pump: Mini Red Dragon 600
Delivery rate: 625 l/h Air inlet ~ 800 l/h Water inlet
wattage - active power: P = 18 Watt/h
operating voltage: 230 Volt 50 Hz
Protection class: IP 68
Water level: ~ 150 mm up to ~ 200 mm
Weight skimmer: 5 kg inclusive pump
Dimension skimmer without pump:
195 mm wide / 245 mm length / ~ 500 mm height
Dimension skimmer with pump (90° to the torque tube):
220 mm wide / 245 mm length / ~ 500 mm height
Dimension skimmer with pump (compared the torque tube):
220 mm wide / 390 mm length / ~ 500 mm height
The skimmer has default 2 pump connection options.
AQUABELLA
Return to Aquabella Aquariums
