[b]System Type: Mixed Reef
[color=blue]PICO System:[
[b]PICO Tank: 25cm cube
PICO Volume: 19.7l with sump
PICO Lighting: Lighting specifications. 18w aquastyle pendent
Start up date: Day PICO was first filled and cycling commenced. 30/12/13
[color=blue]Support systems:
Display Water circulation: In tank water circulation. 600lh return pump
Filtration: Are you running any filtration equipment? Sump with chemi pure elite
Evaporation Top Up: Auto top-up
Water Changes: Water change regime, volume and frequency 5l weekly
Calcium and Alkalinity Addition: How are you maintaining Calcium and Alk levels
Other Chemical Maintenance: Magnesium, additives etc
Current Water Chemistry: If applicable haven't tested yet
Livestock: just a pice of live rock
Corals: What corals have you got in the tank
Invertebrates and or CUC What have you got in there?
Feeding Regime:
Coral food: What are you feeding, how much and when.
Method: What method do you use to feed.
Budget
Equipment expenses list the costs of the equipment you have purchased for the Tank
Tank & sump made by reefsavers out of off cuts from a tank build
Cost I have to shampoo his lounge room carpet
Return pump $25
Light already had from a old nano setup $0
Cooling fan already had from last nano
Fan controller $18 eBay
Auto topup had siting in the cupboard for years ( aqua medic )
Will put some up when I can work out to how to paste them from my iPad
