Lin's 18.44L pico - Neptune's Garden - shutdown
For details, discussions and Tank Journals for this years Pico tank competition
Moderators: Moderators, Promotions, Competitions & Sponsorship
Re: Lin's 18.44L pico - Neptune's Garden - Corals in
Postby linnx » Wed 08 Jan, 2014 12:47 am
Day 8
Bak Low: 1 drop
Food7 Low: 1 drop
Start3 Low: 0.1ml x 2
i have bio film on the glass now. also i can see some diatom on the glass and rock. Tank is almost cycled.
I have rescape a bit and glued everything on. also put few morph in the blank space of the rockwork.
all my sps, goni and zoa seem doing very well
Current FTS
Front
Side
stupid iphone :grump: :grump:
Pico Competition - Neptune's Garden: http://masa.asn.au/phpBB3/viewtopic.php?f=192&t=254550
3x1.5x2 Mixed Reef - BioPellets with Zeovithttp://www.masa.asn.au/phpBB3/viewtopic.php?f=148&t=248992
linnx
Postby linnx » Wed 08 Jan, 2014 11:42 pm
Day 9
Bak Low: 1 drop
Food7 Low: 1 drop
everything looks good so far.
linnx
Postby linnx » Thu 09 Jan, 2014 11:38 pm
Day 10
Bak Low: 1 drop
Food7 Low: 1 drop
Diatom become darker and move visible but only at one spot tho. i am guess that gets the least flow. going to do water change again on the weekend but will do a water test before that. with zeovit method you need to skim out the bacteria but i guess the zoa and goni may enjoy that and had that taken care of very well at the moment.
linnx
Postby linnx » Sat 11 Jan, 2014 2:46 am
Day 11
Bak Low: 1 drop
Food7 Low: 1 drop
linnx
Postby linnx » Sun 12 Jan, 2014 2:07 am
Day 12
Bak Low: 1 drop
Food7 Low: 1 drop
a lot of diatom has appeared in different area of the glass. 2 days before the tank should be cycled.
linnx
Postby NewyReefer » Sun 12 Jan, 2014 8:38 am
Gotta love the zeo cycle, looking tops Lin hows your parameters going.? are you going to put any livestock in.?
Postby linnx » Sun 12 Jan, 2014 11:26 pm
Day 13
Bak Low: 1 drop
Food7 Low: 1 drop
Tomorrow is the water test day.
linnx
Postby MeLLeR » Mon 13 Jan, 2014 11:47 am
Cool :thumbsup:
I used food7 once I had low nutrients, but used sponge power for the initial cycle and then alternated dosing SP and F7. Seemed to work well :)
MeLLeR
Postby linnx » Mon 13 Jan, 2014 5:01 pm
MeLLeR wrote:Cool :thumbsup:
i was going to use more sponge power when cycle finished.
linnx
Postby linnx » Mon 13 Jan, 2014 5:39 pm
water test day:
All done via Red Sea
Nitrate: 2ppm
Phosphate: 0.08ppm
Cal: 365ppm
Alk: 6.7 DHK
salinity: 1.025
linnx
Postby linnx » Wed 15 Jan, 2014 1:20 am
50% water change today
Come up with a dosing schedule and here is the snapshot
Put in a purple birdsnest to replace the brown acro (only for water testing not expecting it to colour back in this tank)
Put another Teal coloured yellow polyps acro. Both glued on the rock platform i built for SPS.
1 more goni frag - a sunset goni
will take some photos tomorrow if i have time.
1 turbo snail in to help with algae and diatom.
linnx
Postby linnx » Sun 19 Jan, 2014 2:30 am
Haven't got time to take photos
but did water change again today and followed by some water test
Nitrate:0.5
Phosphate: 0.08
Calcium: 375
Alkalinity:6.3
Nitrate has reduced but phosphate has remain the same. Will increase bak dose to 3 times a week. Not sure why buy my small bag of rowaphos doesn't seems work for me.
water change can't seem to keep up with the Cal and Alk so i decide to do some manual dose of Red Sea A and Randy's B.
linnx
Postby linnx » Sat 01 Feb, 2014 12:45 am
been busy with the other tank but i still manage to do the bi weekly WC and stick with the feeding schedule. Recently i changed to use ASW so i can get stable parameters.
Did WC change today and did some water test. only did Cal and Alk
Cal: 450
Alk: 8.4
Hopefully i get some spare time tomorrow to do the NO3 and PO4 test and take some nice shot of the tank and coral.
linnx
Postby linnx » Thu 20 Feb, 2014 10:53 pm
Been very busy recently so have't done much on the tank.
i did take out a acro frag that is not doing good and replaced with couple gorg frags. took the media rack out and put in a small air stone driven skimmer.
one of my goni frag is not opening. i am guessing due to the excess nutrients in the water. i am going to do some test this weekend.
linnx
Postby linnx » Thu 06 Mar, 2014 8:52 pm
it has been almost impossible have time to take care this little tank i have. i have been back to weekly water change and for the last 2 weeks i have not changed any water with this tank. still feeding it if i remember but that's about it.
zoas are doing good, gonis....not too bad. but they are dirty water lover anyway or they can survive in a little bit Nitrate and Phosphate. Work and family just keep me busy and i still need to dedicate some time to the bigger tank.
wife is due in about 2-3 weeks so i am thinking to shutdown this tank and quit the competition. i will see if i can spare some time to clean the tank and take some decent photo before i decide to close it down. Need to send mum to airport on Saturday so then i may have bit time.
linnx
Postby linnx » Mon 10 Mar, 2014 11:55 am
Work is getting busier and wife is due in 2-3 weeks. I have not been able to dedicate enough time to the tank it deserves to. so i decided that i will shutdown this tank and move most of the stock to my big tank so corals are getting a more comfortable environment to live with.
Here are some photos before i shut it down:
linnx
Return to RTAW PICO competition
