Save 25% on LED's with pendant systems!
This forum is run by Dalua Australia (a MASA Business Partner). Please feel free to use this forum to discuss any topics about products, sales or any general questions you would like us to answer.
Postby dalua_australia » Wed 10 Jul, 2013 3:51 pm
Hi guys!
We are currently showing off a new campaign exclusive to ILLUMAGIC! It's actually a campaign in "Downselling" to our customers! This below strategy only works on tanks with more of a centre scape of plants and corals as opposed to end to end planted or coral tanks!
So basically with the ILLUMAGIC pendant hanging system you can save yourself 25% on retail pricing and a further 25% on your electricity bill!
The trick is to purchase an LED lighting system one foot short than your tank length! So for a 120cm tank you would purchase the 120cm pendant system with a 90cm ILLUMAGIC BLAZE unit! We again want to make sure that your tank inhabitants are flourishing so make sure that your tank is set up in a more centre landscape style.
By using this approach you can purchase a shorter LED unit saving you on the retail purchase and of course with 25% less LED's you will save 25% on your already cheaper electricity bills!
Check out the in depth video here: http://youtu.be/5kkT1ZwoTvA
When LED's first came out it was all about the ENERGY SAVINGS! But some of the other LED brands out there run as hot and as much power as the old metal halides! This is just expensive and doesn't do anything beneficial for your tank except promote more algae! So please remember, generally tanks no deeper than 75cm do not need the overpowered LED units, they are just costing you more money!
Contact us now for advice, or other LED options! Thanks and good luck with your aquariums!
DALUA AUSTRALIA No.1 Choice in LED Lighting
http://www.daluaaustralia.com.au
info@daluaaustralia.com.au
0406111223
dalua_australia
Re: Save 25% on LED's with pendant systems!
Postby sammydog » Thu 11 Jul, 2013 1:26 pm
What size Illumagic Blaze would you recommend for a 70x70x70 cube?
I'm intending to get an Illumagic Blaze and a new cube, just deciding on whether to upgrade my tank or lights first.
sammydog
Postby dalua_australia » Fri 12 Jul, 2013 12:45 am
A 60cm Blaze would suit perfectly if you want extra light to get perfectly to all corners, if you have a centre scape than you can get away with 45cm blaze with a 80cm pendant system.
What's your closest or preferred LFS?
0406111223
dalua_australia
Postby sammydog » Fri 12 Jul, 2013 9:22 am
Thanks, I was thinking the 60cm would be better.
Tank Aquariums in Belmont will be where I purchase from. Love their setup where they have the lights running. I just need to settle on whether I am going to upgrade the tank or lights first.
sammydog
Postby dalua_australia » Sat 13 Jul, 2013 12:33 pm
Great stuff, they have a fantastic ILLUMAGIC BLAZE display!
Good luck!
0406111223
dalua_australia
Postby sparker » Mon 02 Sep, 2013 3:39 pm
what size would you recommend for a 6ft long tank using this system?
Thanks,
Sam
sparker
Postby dalua_australia » Mon 02 Sep, 2013 10:46 pm
sparker wrote:what size would you recommend for a 6ft long tank using this system?
Thanks,
Sam
Hi Sam. You would have to go a 6 foot pendant system with a 5 foot Illumagic Blaze unit, check out this youtube video here to see a smaller version of your desired look.
http://www.youtube.com/watch?v=5kkT1ZwoTvA
Any further questions please do not hesitate to contact us anytime:
orders@daluaaustralia.com.au
0406-111-223
0406111223
dalua_australia
Postby sammydog » Mon 02 Sep, 2013 11:59 pm
Have you got any other shots/videos of a 60cm light on a 90cm tank?
I am about to build a 90x60x60cm tank and am sitting on the fence between the 60 and 90cm lights, probably still more towards going the 90cm light. If I went the smaller light option would that rule out SPS in the future, or just limit it to the centre of the tank?
sammydog
Postby dalua_australia » Tue 03 Sep, 2013 6:28 pm
sammydog wrote:Have you got any other shots/videos of a 60cm light on a 90cm tank?
On our facebook we have a 90cm light hanging from a 120cm tank, check out the pics here: https://www.facebook.com/media/set/?set ... 053&type=3
And also a 5 foot blaze on a 6 foot store display can be seen here: https://www.facebook.com/photo.php?fbid ... =3&theater
As you can see there is slightly less light around the corners only, so you are not only limited to the centre of the tank as such but more centre, front and back but leave the corners to the LPS.
Any other questions feel free to contact us anytime!
0406111223
dalua_australia
Return to Dalua Australia
