gippslands small cube
Postby annie » Sat 30 Jan, 2010 2:24 pm
Well this is my second reef tank the original I had was a 3' x 18 x 18"
Had no sump, simply a learning curve. That lasted 12 months and now have progressed to a 2' cube. Simply this size so as not to cost a fortune and to have it in the lounge room. This is my first tank journal but I have been following this forum for a long while. You will have to bare with me as I'm not very computer savvy, so excuse all the stuff ups I might course. As the title suggests we live at Woodside in south Gippsland which is a wonderful area out on the water in the boat and doing a bit of snorkling with the family.
So here goes:
System Objectives: What is the end result going to be?
A better understanding of reef habitation.
System Type: Mixed reef
Display system:
Strike up Date: October 2009
Display Tank: cube 2'
Display Lighting: T5 8 x 24w with individual reflectors
Stand: came with cube with space for sump
Hood: Nil
Sump: 3 x 20ltr plastic drums with top cut off and attached with a bulk head between each. Works well.
Refugium: have not started as yet but 3/4 full deep sand bed
Refugium Lighting: starting soon with just a lamp globe
System water: Natural salt water
Display water circulation: Closed loop system. Drilled 6 holes in tank. 3 holes across the back up top. 2 holes on either side down low. 1 hole drilled in the bottom for the standpipe.
Return pump: Eheim compact
Skimmer: Reef Octopus
Evaporation top up: Manual
Chemical support:[color]
Calcium addition: manual if needed
Alkilnity addition: manual
Magnesium: manual if needed
Current water chemistry:
Nitrates: 0
Phosphates: 0
Alkalinity: 9 - 10
Calcium: 470
Salinity: 1.024
Magnesuim: 1540
[color=blue]Images:
Now the hard bit uploading the pics and trying to get some decent shots.
Stay tuned.
annie
The Gippys cube
Postby annie » Tue 02 Feb, 2010 2:56 pm
more photos of the tank coming up soon.
Its all new to me so hope not messing people up to much
annie
Postby nickstoyaa » Sun 07 Feb, 2010 10:20 am
love the sump :) good cheap DIY there :)
Cheer's, Nick.
nickstoyaa
