Matt's Aqua Nano 40
Matt's Aqua Nano 40
Postby MattnJayne » Sat 24 Aug, 2013 8:45 pm
New to the world of Marine but kept fresh water tanks back in my youth. Had always wanted to set one up as back in the day my Brother in law had a marine tank back in the days where trickle filters were all the rage.
Firm believer of doing things right the first time so I have probably gone for overkill on a nano!!
System Objectives: Healthy system that will be done in baby steps having spent countless hours reading on here about how it’s all about baby steps!
Display System: Aquaone Aquanano 40 that I got off Gumtree and had only been used for a month as a Fresh Water tank
Strike up Date: Possibly September, still trying to decide as I am going OS in December for a week. If I do start in Sept, I will just cycle for an extra-long time.
Display Tank: 40x40x40, Display is 40L with the rear chamber being 15L
Display Lighting: At this stage it will just be the standard light that came with the tank with a marine tube in it but want to upgrade to LED. Am currently looking at the Maxspect Razor Nano, though I may end up looking at a new light to the market being the MicMol Aqua Mini Colour.
Stand: Standard AquaOne stand that is 40x40x80
Hood: No hood
Sump: built in sump at the back.It consists of three chambers, first will have the skimmer, the second chamber I hope to build a small media rack out of egg crate that I can run possibly Carbon if I need to and ROWAphos, third chamber contains return pump and ATO and heater.
Display Water circulation: Vortech MP10. Yes I think this is overkill but I will just dial down the flow. (Not on the tank yet)
Return Pump: Eheim Compact 600
Skimmer: Tunze 9002. I could probably just do water changes to keep things under control but I thought if I am going to set up a tank, may as well do it properly.
Evaporation Top Up: Auto top up – Tunze 3152 which is the nano version of its big brother.
Front
Complete System
With Light
Back
Trying to decide if to build a media rack in the middle section and another one under the skimmer to run filter floss..Thoughts?
Progress will be fairly slow on this for a little while as the MOF has stated no more buying until my bonus has come through which is not until mid Sept.
Tank is in the spare room until its ready to be filled.
Appreciate you looking.
MattnJayne
Re: Matt's Aqua Nano 40
Postby 555combo » Sun 25 Aug, 2013 10:18 pm
Will be following along to see what ideas I can steal.
Good luck.
Aaron.
4x2x1.5 Mixed Reef
AquaNano 40 Tank Journal - Now Shutdown
555combo
Postby priscacara » Mon 26 Aug, 2013 10:16 pm
Nice looking setup, looking forward to seeing how it develops.
Postby MattnJayne » Thu 05 Sep, 2013 9:30 pm
So not much to update other than next Saturday 14th I will be getting NSW delivered to start the tank cycling.
Should have some eggcrate this weekend so that I can make a media rack to run carbon and Rowphos.
Next on the list will be to pick up the MP10 off NotsoMot and to order the aqua mini from Micmol.
Will post up photos next weekend.
MattnJayne
Postby scottii2coope18 » Thu 05 Sep, 2013 9:41 pm
Woot micmol :)
Scott Cooper - "Reefing the addiction that doesn't stop"
scottii2coope18
Nudge Nudge Wink Wink Know What I Mean
Postby some_one » Fri 06 Sep, 2013 12:25 am
Looks like it is coming together nicely Matt.
I would do away with the filter floss though :thumbsup:
Brett
From WA, join MASWA!!
some_one
Postby MattnJayne » Fri 06 Sep, 2013 12:29 am
some_one wrote:Looks like it is coming together nicely Matt.
Yeah wasn't too sold on the idea of filter floss.
MattnJayne
Postby NewyReefer » Sat 07 Sep, 2013 6:28 pm
looks like your off to a good start mate looking good :clap: ...
tho if i was you i would run some sort of mechanical filtration, in the sump section of mine i have the first chamber as skimmer second full of live rock and third as the return, heater, phosban pump and canister filter return.
i had to add a small canister filter just for filter floss and rowacarbon (thats all no bio media) and i have to clean it once a week its amazing how much s**t it pulls out, even with a phosban reactor my p04 was at 0.44 before i added it to(now 0.00).
just a heads up your heater wont work there i had an issue with the way the water flows straght under the last baffle to the return pump there is no flow around the heater, so having the return from my canister there helped the flow..
Cheers :thumbsup:
P.S. thats 1 week of junk i personally wouldnt want to leave that floating around my tank.
Postby MattnJayne » Sat 07 Sep, 2013 6:37 pm
Hmm I have no where else to put my heater as I plan to build a media rack in the section section
MattnJayne
Postby Gobzy » Wed 11 Sep, 2013 11:48 pm
fellow AN40'er :wavey: looks like we're roughly at the same level so good luck to both of us!
nice hardware selection there.. i'm assuming im not alone in finding buying and setting up the hardware as exciting as the livestock? weird perks of the hobby :o
Does your tank have the slit at the bottom, at the base of the overflow vents? it will leak some water in there.. i actually managed to seal mine even after i added water, didn't think it would set but it did..
Gobzy
Postby MattnJayne » Wed 11 Sep, 2013 11:57 pm
Gobzy wrote:fellow AN40'er :wavey: looks like we're roughly at the same level so good luck to both of us!
Yeah I have already sealed that up plus the the first overflow was not sealed at the bottom so I have fixed that.
People are saying the heater in the last section won't work so I will see how I go over the weekend to see if it heats the tank or not
MattnJayne
Postby 555combo » Thu 12 Sep, 2013 2:52 pm
You might be able to make an eggcrate stand to lift the pump a little from the bottom of the return section and shorten the return pipe if you find the heater isn't working well enough.
I see the point that is being made, worth experimenting with, mainly so I know what to do when I replace my return pump. :-D
Aaron.
4x2x1.5 Mixed Reef
555combo
Postby Jazzhands » Sat 14 Sep, 2013 8:05 pm
Wet yet? :o it's the weekend!
Jazzhands
Re: Matt's Aqua Nano 40 - it's WET
Postby MattnJayne » Sat 14 Sep, 2013 8:30 pm
Jazzhands wrote:Wet yet? :o it's the weekend!
So delivery of NSW was delivered this morning and then it was a trip out to Vebas to get the live rock.
Got just over 5kg in there which should be enough.
Will post some photos up soon.
There is just a slight problem in that the water is quite cloudy so hopefully it clears soon. :thumbsup:
MattnJayne
Postby Jazzhands » Sat 14 Sep, 2013 8:55 pm
I've been oddly excited for you! Can't wait to see ^_^
Jazzhands
Postby MattnJayne » Sat 14 Sep, 2013 11:22 pm
okay as promised, here are some photo's. apologies for the them though as its still a little cloudy.
Haven't switched the skimmer on yet and I have only tested Salinity so far which was 1.026. I will test tomorrow if I get the chance but will be out most of the day.
Seen no signs of life yet..will post a better pick once its cleared up.
MattnJayne
Postby Jazzhands » Sun 15 Sep, 2013 1:09 pm
Off to a great start! :D
Jazzhands
Postby MattnJayne » Sun 15 Sep, 2013 2:53 pm
This morning I tested the water for the first tim using Salifert test kits.
Salinity :1.027 (a little high so I will monitor)
Temp: 26.3 - still getting use to the Jager heater so I have turned it down so hopefully it will settle in the 25 range
Nitrates: 0.5
pH: 7.7
Alk/Kh: 6.4
Ca: 360
P04: 0.03
Mg: 1140
Now some of these readings dont seem right t me (too low) so I will check again maybe in a few days time to see if it was me being a newbie and not testing right.
Havent seen any forms of life as in crabs, shimps, worms but I do have a few things that retract back into the rock when I get close or touch them..will post photo's up later of what they are and now that the water has cleared also..
MattnJayne
Postby Gobzy » Sun 15 Sep, 2013 6:09 pm
nice progress. nitrates already is interesting i didn't think they came until your nitrites began converting but what would i know!
I had worries with my standard heater.. i noticed the light was on quite constantly and thought it wasnt working great, i went and got a new eheim heater and noticed it's on around the same time.. the temp is fine so they were both working.
I saw no hitchikers however i've had clicking in my tank since beginning although i've never seen the culprit.. either a pistol or mantis shrimp from what i've read.
Gobzy
Postby reef4u » Sun 15 Sep, 2013 8:22 pm
Hey matt
Not sure how long your tank has been up for but I wouldn't stress about testing etc. straight away. Sometimes you can get weird results while the system is stabilizing. I left mine for 2/3 weeks just topping off evap as required.
I would just let it settle... then you can have fun working out what is happening.
reef4u
Postby MattnJayne » Sun 15 Sep, 2013 9:22 pm
So I turned the skimmer on this morning and not seeing muck skimate atm but I know that it wont happen given there is little to no bioload and the skimmer needs to run in. I have it on the lowest setting so will watch over the coming days and make adjustments as needed.
Here is a better shot now the dust has settled.
Plus the only life forms I have seen so far as below. It retracts if it is touched or spooked. Any ideas as to what it is?
MattnJayne
Postby MattnJayne » Sat 21 Sep, 2013 4:48 pm
week 1 of cycle...
This morning I did a 10% water change and then waited a few hours and then tested, results are:
Salinity: 1.026
Temp: 26.1
NO3: 1 :wall: :wall:
ph: 8
Alk/KH: 5.7
Ca: 350
PO4: 0.03
Mg: 1110
skimmer has broken in but still trying to fine tune it.
MicMol aqua mini colour has been ordered and will hopefully be here by next week or the week after.
I am using the original aquaone pump for flow inside the tank until I can pick up the MP10 off another member.
May do a mid week water change to reduce the Nitrates but given this is week 1 of the cycle I might just leave it and see how I go next week.
MattnJayne
Postby Gobzy » Sat 21 Sep, 2013 4:59 pm
hopefully someone more knowledgeable can correct me if im wrong but again i wouldnt worry about the nitrates.. at the early stage it's only worth monitoring ammonia and then nitrite, with the subsequent spike and drop off as per the cycle..
I didnt do a single water change in the 4 weeks my tank cycled.
I'm jealous you have a skimmer, mine has no room for the conventional ones people use with this tank so im looking into some hang-on-back options
Gobzy
Postby NewyReefer » Sat 21 Sep, 2013 6:44 pm
Yep you will go through a spike of ammonia then nitrite then it will go to nitrate.
in nano tanks tho the process should only take about a week if your lucky.
also 1ppm of n03 is good man if you have under 10ppm is ok
Postby MattnJayne » Sat 21 Sep, 2013 6:48 pm
NewyReefer wrote:Yep you will go through a spike of ammonia then nitrite then it will go to nitrate.
Good to know that 1ppm is okay. :thumbsup:
MattnJayne
Postby reef4u » Sat 21 Sep, 2013 7:08 pm
How do you know week 1 of the cycle? I would just leave it alone for a few weeks and don't stress. There is no point water changing and testing on such a new system, it hasn't even had a chance to spike and come back down.
reef4u
Postby some_one » Sun 22 Sep, 2013 11:26 am
MattnJayne wrote: NO3: 1 :wall: :wall:
Good sign :thumbsup:
Especially if the rock was fairly fresh into the LFS.
Ammonia -> Nitrites -> Nitrates :banana:
Brett
some_one
Postby MattnJayne » Sun 22 Sep, 2013 1:12 pm
Well even if it is a good sign, I am still waiting until I put anything in it.
MattnJayne
Postby MattnJayne » Sat 28 Sep, 2013 12:35 am
So today my new MicMol Aqua mini light arrived and I must say that for the price, the light so far is pretty good.
Its build quality is really good, though I did have a little trouble putting the arm extension bracket into the actual unit. Got there in the end with going in on a slight angle.
Its just running on the preprogrammed mode at the moment but I will have a play with it over the weekend at some stage and set it how I want it.
Anyways enjoy the pics (taken from my iPhone so I apologise in advance)
Moonlight
100% all channels
MattnJayne
Postby Jazzhands » Sat 28 Sep, 2013 3:12 am
That's a sweet looking light! Might have to grab one myself!
Jazzhands
