Vertex Mocean Review
Postby Aquadepot » Mon 28 Oct, 2013 2:03 pm
Aquadepot Imports
info@aquadepot.com.au
http://www.aquadepot.com.au
https://www.facebook.com/pages/Aquadepot-Imports/327760543977587
National Distributors/ADA/ ARKA / AquaPlant Culture / GHL / Neptune=Apex controllers / Kamoer / Korallen-Zucht / Salifert / Tunze /FIRE UltraClear Aquariums
ALL KZ PRODUCTS CAN BE USED WITHOUT ZEOVIT SYSTEM and with any other products
Aquadepot
Re: Vertex Mocean Review
Postby graham 101 » Fri 01 Nov, 2013 7:17 pm
Well once again Graham thank you for bring in one of the best products into Australia. :bow: :bow: As you know from my latest purchase from you were two of the perfect wave/current makers :thumbsup: . I was not expecting this to be such an impressive little system. :angel: There is no noise with these systems and the best thing of all is so easy to work. :clownfish: I have placed a Tunze 6045 under the elbows and man this is the bomb. :cheers:
So all I would like to say to fellow reefers :poke: out there get onto the Mocean wave. :roflmao:
:clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap:
graham 101
Postby Heliman » Sun 01 Dec, 2013 1:58 pm
I have been running 2 of these units for 18 months now. Totally quiet, totally reliable and do an awesome job.
Only small criticism...if the power goes down, you need to reset them from scratch. Other than that, cant fault them
Heliman
Postby petergriffin » Tue 03 Dec, 2013 1:15 am
Was thinking about these... but do they reset to 360degrees when then power goes out? If they do will this cause an issues with 5000 LPH running through it?
JOIN MASWA TODAY... I HAVE OPINIONS GET USED TO THEM, IM NOT GOING ANYWHERE!
petergriffin
Images: 23
Postby Heliman » Fri 06 Dec, 2013 10:26 am
petergriffin wrote:Was thinking about these... but do they reset to 360degrees when then power goes out? If they do will this cause an issues with 5000 LPH running through it?
They stop completely in the position they were in the rotation cycle when the power goes out.
If youre unlucky, they could stop when pointing at an aquarium wall...could get overspill in a rimless set-up. With rimmed tank, should be a little less dangerous !!!
So far I have had 2 power outs and Moceans stopped in a non-problematical position...but ......next time ?????? :crossfingers:
Heliman
Postby chromus » Fri 06 Dec, 2013 11:17 am
Could you battery backup the units?
Graeme, has the manufacturer mentioned a workaround?
Return to Aquadepot Imports
