Neptune Apex Available soon
Postby 7044scott » Sat 15 Mar, 2014 1:48 pm
Hi I have my lights set to come on every day from 4pm till 11pm I would like to know how I can run them at ten% on the weekends from 8am till 4pm
7044scott
Re: Neptune Apex Available soon
Postby Aquanet » Sun 16 Mar, 2014 6:20 pm
Set up the Apex this weekend for a test run,
Great little unit, had the webserver up in 30mins.
One thing i found is that it is not easy to program like the GHL. still trying to get my head around it, But they have a great manual.
Who has signed up for Fusion? looks like it is open to test, but only a few a day can get access.
http://www.neptunesystems.com/apex-fusion-beta/
Aquanet
Postby ggoosen » Sun 16 Mar, 2014 6:29 pm
I am an apex fusion beta tester, you can sign up but it's unlikely that you will why an invite , I know many users are asking for access on the Neptune forums
ggoosen
Postby Aquanet » Sun 16 Mar, 2014 10:27 pm
?? You don't need a invite. It's now open , but they are limiting it daily.
Aquanet
Postby ggoosen » Mon 17 Mar, 2014 10:40 am
Aquanet wrote:?? You don't need a invite. It's now open , but they are limiting it daily.
ggoosen
Postby Aquanet » Mon 17 Mar, 2014 6:26 pm
Reeftronics is cool, sends me email if my Apex is down.
https://www.reeftronics.net/
Aquanet
Postby Aquanet » Tue 18 Mar, 2014 10:10 am
How do you telnet into the apex?
i have the eb6 bar but it will not read the amps as it will need to be reset.
Aquanet
Postby ggoosen » Tue 18 Mar, 2014 12:18 pm
Aquanet wrote:How do you telnet into the apex?
open cmd prompt from a pc attached to your network by doing the following
Start > run > cmd
once command prompt is open,
type in
telnet <ip address of your apex"
eg
telnet 192.168.0.100
that will telnet you to the base unit, once in there follow instructions as needed.
Be careful though telnet is a last resort, and has the ability to reset and or brick your apex unit.
I suggest you read through the comprehensive user guide found Here > http://www.neptunesystems.com/wp-content/uploads/2013/11/Comprehensive-Reference-Manual-.pdf
ggoosen
Postby Aquanet » Tue 18 Mar, 2014 1:08 pm
i can get into dos, but i get to this
c:\users\hp>
when i add telnet 192.168.2.101 it comes up with error message.
anyhow, the amp reading is working, not sure how, i had to move the apex and when i reconnected it started to work when i connected a large pump, so all good
Aquanet
Postby chromus » Tue 18 Mar, 2014 3:13 pm
You need to have telnet installed on the machine (its not standard on Home editions) Pro and Ult usually install it by default
Postby ggoosen » Tue 18 Mar, 2014 5:13 pm
chromus wrote:You need to have telnet installed on the machine (its not standard on Home editions) Pro and Ult usually install it by default
ggoosen
Postby Aquanet » Tue 18 Mar, 2014 6:29 pm
Oh, they don't make it very clear in the manual.
Aquanet
Postby Aquanet » Tue 18 Mar, 2014 8:15 pm
where is the best place to get float switch's for the Apex?
Aquanet
Postby chromus » Tue 18 Mar, 2014 8:57 pm
If they are just float switches and dont need a wiring harness
http://www.buyincoins.com/s/float-switch.html
Postby Aquanet » Mon 24 Mar, 2014 8:33 am
Very quite in the Apex world?
Got mine up and running, great unit. The App is pretty fast on the android phone.
Nice web Graphs on reeftronics
Aquanet
Postby NewyReefer » Thu 27 Mar, 2014 5:16 pm
Is anyone running fusion yet..? i got my invite but cannot generate a token..??
Postby NewyReefer » Thu 27 Mar, 2014 6:47 pm
Postby Aquanet » Thu 27 Mar, 2014 7:23 pm
Yep, been running for a week,
Token should come up on the standard dashboard
Aquanet
Postby NewyReefer » Thu 27 Mar, 2014 7:30 pm
Yea I ended up getting it but I had to get it from the apex display. ..
Also I have updated the firmware but fusion is saying it's not the latest and there is nothing on my fusion dashboard. ?
Postby Aquanet » Thu 27 Mar, 2014 9:35 pm
Try the neptune support, they are pretty good
Aquanet
Postby NewyReefer » Fri 28 Mar, 2014 5:13 am
Thanks mate will give that a go...
Postby Aquanet » Fri 28 Mar, 2014 7:18 am
Been playing with Fusion, found that you can view other controllers if they load you as view.
pretty cool, but you have to have Fusion.
Aquanet
Postby NewyReefer » Fri 28 Mar, 2014 9:06 am
Yea I have seen that you can authorize other people to view and receive warning emails pretty handy....
Postby Aquanet » Fri 28 Mar, 2014 9:29 am
sent you a PM
Aquanet
Postby NewyReefer » Fri 28 Mar, 2014 9:34 am
Sounds good mate.
I did try and reply but it said you were unable to receive pm's
Postby Aquanet » Fri 28 Mar, 2014 9:38 am
try again
Aquanet
Postby NewyReefer » Sat 29 Mar, 2014 8:28 am
Got fusion sorted thanks to Aquanet and apex support now is working well.
So good to be able to view and control it outside of my network, also can do it with other peoples Apex would be very handy when your away getting someone else to keep a eye on it.
Postby Aquanet » Sat 29 Mar, 2014 10:57 am
Good it works.
Who else is using Fusion?
Aquanet
Postby ggoosen » Sat 29 Mar, 2014 10:45 pm
Aquanet wrote:Good it works.
Me
ggoosen
Postby NewyReefer » Mon 31 Mar, 2014 5:52 pm
Has anyone got there Apex linked to Aquaticlog..??
Return to Aquadepot Imports
