Vertex Illumina LED Pads (Red)
Postby rodneyri » Wed 15 Jun, 2011 1:03 pm
So the new color pads are coming out shortly, do we have a price list yet or any info on these.
rodneyri
Re: Vertex Illumina LED Pads
Postby Aquadepot » Wed 15 Jun, 2011 2:03 pm
Yes red pads will be available in a few weeks.
I will try and get pricing this afternoon.
Graeme
Aquadepot Imports
info@aquadepot.com.au
http://www.aquadepot.com.au
https://www.facebook.com/pages/Aquadepot-Imports/327760543977587
National Distributors/ADA/ ARKA / AquaPlant Culture / GHL / Neptune=Apex controllers / Kamoer / Korallen-Zucht / Salifert / Tunze /FIRE UltraClear Aquariums
ALL KZ PRODUCTS CAN BE USED WITHOUT ZEOVIT SYSTEM and with any other products
Aquadepot
Postby rodneyri » Thu 16 Jun, 2011 8:13 am
any news Graeme?
rodneyri
Postby rodneyri » Mon 20 Jun, 2011 7:40 pm
no updates ?
rodneyri
Postby spanishmack » Mon 20 Jun, 2011 9:05 pm
good things come to those who wait, great things come just a little later.
spanishmack
Postby Aquadepot » Tue 21 Jun, 2011 1:41 am
I spoke with Vertex late last week and the pads are in production and they hope to give me pricing early this week maybe tomorrow :crossfingers:
Graeme
Aquadepot Imports
Aquadepot
Postby rodneyri » Tue 28 Jun, 2011 8:10 pm
still no news?
rodneyri
Postby Vertex Aquaristik » Tue 28 Jun, 2011 11:20 pm
Sorry for late reply,
I just talked to the production department and the reason why the pricing have not been published is that you will need 2 different products to perform an upgrade or add Auxiliary modules:
1- Red Auxiliary Module
2- Upgrade kit
The modules are in stock and ready to ship.
The upgrade kit will consist of special Key for our screws, screws, push device and No bake thermal grease.
The modules are seated on the top of a heat-sink plate with piercing contacts extending out from the other side of the heat-sink.
These contacts pierce the onboard power distribution cable that run inside the Aluminum profile along the side of the lamp. Image
Once the contacts are inside the cable the PVC jacket will create a gas-tight connection.
The push device fits both the Primary module and the auxiliary module.Image
Push device is placed on the top of the PCB. Pressing against the push device the user will push the piecing contacts into the cable and make a connection. Image
This will distribute the force evenly along the whole surface of the PCB and will protect the PCB from getting damaged by the force applied to install it.
There will be no soldering, wiring, marrette…
All these features have been in the lamp design from the beginning however our engineers have been swamped with so much work on Cerebra that this simply lost priority! In actual fact we did have these onboard our fixture at Interzoo over a year ago!
We are releasing the Red modules now, you will not need to fill all he available slots for the Auxiliary modules with Red AUX modules, in my mind about 30% of the slots filled(or less) will be more than enough since these are strong Red LEDs.
So for example in a SR 1200 model you will have 7 spots for Aux modules and I believe 2 or 3 modules would be more than enough to even create a red sunset effect.
Good news is that after I beg for another 3 months we will also have AUX modules in Green, violet and possibly other colors!
As for pricing since the production needs to send the bill of material to marketing to determine a price this is always a very fast process, ooops I meant not so fast!
In other makes if you like to have other color LEDs you will have to remove LEDs and replace with new colors which in our mind will change the color out-put balance of the lamp.
Here you will have the color you already prefer composed by White, Blue and Royal Blue LEDs onboard the fixture and then you can further accent the out-put with other colors without having to sacrifice intensity. Simply because you are not losing white LEDs to add other colors.
Now having said all that, they forgot to order packaging for the modules and the upgrade kit and the NO-BAKE thermal grease must be filled in one-time use syringe so the user can easily apply it between the heat-sink and the Aluminum body of the lamp!
So basically simple case of the brilliant engineer working on design and forgetting to ask us to order syringes and packaging!!!!!!!!!!!!!!!!!!!!
The modules will be ready to ship in 2 weeks and pricing should be released sometimes next week!
I hope this helps and once again sorry for delay.
Best regards
Vertex
Vertex Aquaristik GmbH:, 50858 Cologne, Germany,
http://www.vertexaquaristik.com
Vertex Aquaristik
Postby rodneyri » Wed 29 Jun, 2011 1:45 pm
thanks for the update, i have a question though...will the software be updated to control the additional color pads available so can i ramp up the red and control it as i do the white/blue/royal blue?
rodneyri
Postby Vertex Aquaristik » Fri 01 Jul, 2011 3:26 am
There is no need to update the software, as I mentioned this feature was already implemented into the lamp from day one.
Once installed the controller on-board will detect the new hardware and red module control menu will appear same as the other colors onboard.
Vertex Aquaristik
Postby spanishmack » Fri 01 Jul, 2011 8:48 pm
Great to see you posting here Vertex :thumbsup:
Have you considered other colours? a yellow or orange pad?
what would be nice is 2 colours to each pad so i could have 6 extra colours to fine tune on my 600mm fixture :roflmao:
I am more than impressed with my sr600, it is a nice light :clap:
Jason
spanishmack
Postby Vertex Aquaristik » Fri 01 Jul, 2011 10:55 pm
Jason,
Your wish is my command Sir!
I will soon start a thread getting everyone’s opinion on colors they would like to see.
Bicolor pads are also possible.
Best regards
Vertex Aquaristik
Postby graham 101 » Thu 07 Jul, 2011 7:48 pm
Tell us the price son!!!
graham 101
Postby rodneyri » Thu 14 Jul, 2011 11:17 am
With the dual color pads are you looking at red and violet. I did some light spectrum readings as shown in my tank journal and these colors are missing in the spectrum. Would be good to have these in the unit
rodneyri
Postby Aquadepot » Tue 26 Jul, 2011 1:35 am
The new auxillary Vertex LED package will include the following things:
RED Auxiliary pad, in the box:
1x Pad, 1x Thermal grease 1cc in syringe, screws
Upgrade kit, in a bag:
2x hex keys and 1x push device
We do not recommend filling all the available auxiliary slot on the Illumina Fixtures with Red auxiliary pads, below is what we recommend per each fixture size, however this can be changed according to customers preference.
Below is a number of red LED Modules we recommend for each size fixtures:
Model
Available Auxiliary Slots
Recommended RED Auxiliary Modules
Illumina 300
1 slot
1 RED Module
Illumina 600
3 slots
1 or 2 RED Modules
Illumina 900
5 slots
2 or 3 RED Modules
Illumina 1200
7 slots
3 or 4 RED Modules
Illumina 1500
9 slots
4 or 5 RED Modules
Illumina 1800
11 slots
5 or 6 RED Modules
Aquadepot Imports
Aquadepot
Postby Aquadepot » Tue 26 Jul, 2011 1:42 am
Price release today
Red auxillary module $135.00
Module installation kit $13.00
We will have stock in 2-3 weeks
Graeme
Aquadepot Imports
Aquadepot
Postby rodneyri » Wed 27 Jul, 2011 4:44 pm
thanks for the update Graeme, im still deciding whether to wait for the violet / red mix pads if they become available
rodneyri
Postby aufo8mycat » Sun 07 Aug, 2011 12:31 am
is there any pics any where of the difference with the red panels in!
any way i will order 3 on monday with riki do i 3 installation kits or will the one do it! alos will be ordering a sr600 for some crazy reason i wanna cut up corals and make them grow next to my tank! i think it so i dont loose anything should the angel get the munchies
MASOG Committee Member
Those who believe in telekinetics, raise my hand
The 4P's Tank Journal
The SPS Tank Journal
aufo8mycat
MASAOG Committee
Postby Aquadepot » Sun 07 Aug, 2011 2:04 pm
aufo8mycat wrote:is there any pics any where of the difference with the red panels in!
We haven't received the auxiliary pads they are due sometime this week, maybe you can post some pics of the reds when you get them installed I am not sure on the number of install kit required, will check and let you know.
Alex maybe you want to try the new illumilux for your quarantine tank?
Graeme
Aquadepot Imports
Aquadepot
Re: Vertex Illumina LED Pads (Red)
Postby aufo8mycat » Sun 07 Aug, 2011 2:29 pm
Nicolas pm'd me yesterday, will just need the 1 install kit i will speak with riki and get him to put in the order and will post pics of diffrence
alex
aufo8mycat
MASAOG Committee
Postby rodneyri » Tue 16 Aug, 2011 12:24 pm
Alex, do you have your red LEDs yet? keen to see some before and after photos if you could.
im waiting for a mix of red and violet myself.
rodneyri
Postby aufo8mycat » Tue 16 Aug, 2011 4:30 pm
rodneyri wrote:Alex, do you have your red LEDs yet? keen to see some before and after photos if you could.
they will be go the country next week so i'm hoping that i'll have them the next day. I ordered 3 for my 1600! Pic's will be up as soon as connected
aufo8mycat
MASAOG Committee
Postby rodneyri » Thu 25 Aug, 2011 11:53 am
any luck with geting the red pads yet?
rodneyri
Postby aufo8mycat » Thu 25 Aug, 2011 11:54 am
there was a hold up with shipping and should be arriving at marine plus on monday or tuesday which is good cos i have wednesday off and can install and have a play then
aufo8mycat
MASAOG Committee
Postby Aquadepot » Thu 25 Aug, 2011 12:21 pm
Red pads shipped from Germany Tuesday we should see them by Monday next week so will be available mid next week.
Graeme
Aquadepot Imports
Aquadepot
Postby aufo8mycat » Thu 25 Aug, 2011 12:37 pm
haha I just bought myself (ops i mean my partener's birthday) a Canon EF 100mm f/2.8 L USM macro so i will be able to take b4 and after shots with reds of coral colour ( i hope)
aufo8mycat
MASAOG Committee
Postby rodneyri » Wed 31 Aug, 2011 11:10 am
did you get your pads yet aufo8mycat?
rodneyri
Postby aufo8mycat » Wed 31 Aug, 2011 12:44 pm
Nope, germany is having postal issues or customs early to mid sept is my new hope
aufo8mycat
MASAOG Committee
Postby Aquadepot » Wed 31 Aug, 2011 12:50 pm
Update on availability of red leds, our shipping company have had some issues with dispatch and the shipment is sitting with the forwarder in Germany now scheduled to leave on the 5 Sept with delivery 9 Sept which is a Friday so we most likely will not have the stock until early the following week.
Graeme
Aquadepot Imports
Aquadepot
Postby aufo8mycat » Thu 08 Sep, 2011 5:04 pm
have they landed yet :)
aufo8mycat
MASAOG Committee
Return to Aquadepot Imports
