NEW PRIME HD ARRIVING ANNOUNCED
This forum is run by Aqua Blue Distribution (a MASA Business Partner). Please feel free to use this forum to discuss any topics about products, sales or any general questions you would like us to answer.
Postby AquaBlue » Thu 16 Jun, 2016 3:11 pm
What's New?
HD Power
No longer are you limited to using a fixed amount of power per channel, the HD dynamically adjusts power available to each color, borrowing power from the colors you’re not utilizing. Giving you the most vivid spectrum your tank has ever seen.
The HD Power Difference
Check out the PAR difference between a normal 20K color setting and one with HD enabled. Par increases from 64 to 100!
Prime HD PAR
36" x 36" inch area at a height of 24 inches over open air.
Power Output
With a spread of 24" x 24", the AI Prime® HD has a peak PAR of 100µMol at a depth of 24 inches, more than enough for your hungriest of livestock. Drawing a maximum of 55 watts from the wall, it follows in the family’s efficient footsteps.
Proprietary Color Blending Lens
Optics
The AI Prime® HD comes standard with 80 degree lenses giving you the best balance of power and spread. Our lens optics are custom designed, boasting greater than 90% optical efficiency and including a diffuse exit surface to provide improved color blending.
LED Layout
LEDs
The AI Prime® HD utilizes the latest LED technology from leading manufacturers, arranged to provide the best performance.
3 - Cree XP-G2 Cool White (> 70 CRI)
3 - Cree XT-E Royal Blue
3 - Cree XP-E2 Blue
1 - Cree Deep Red 660nm
1 - Cree XP-E2 Green
1 - SemiLED 415nm
1 - SemiLED 400nm
Ask at your LFS and reserve your today!!!
Brisbane, Qld.
http://www.aquabluedistribution.com.au/
AquaBlue
Return to Aqua Blue Distribution
