Introducing Brand New 72W clip on LED lights
Postby Andries » Sun 26 Feb, 2012 5:36 pm
High Power 72W LED CLAMP ON LAMP LIGHT
IDEAL FOR YOUR NANO MARINE AQUARIUM UP TO 2FT
Virtually fit on any size aquarium. The unique design allows you to angle the light where you need it most. With adjustable gooseneck, you can configure the way you want most lighting for the living inhabitants.
Comes with 12 x 3W Bright White (10K) and 12 x Blue (453nm) LED’s to give you the perfect blend for your viewing pleasure and also bring out the most in your fish and coral.
Includes an electronic inline timer-dimmer control to set sunrise and sunset conditions. Dimmer can be bypassed and light can be used without it for a straight forward on/off light fitting.
This light fitting will support all forms of life in a marine aquarium and is superior to an 250W M/H light fitting.
Low voltage gives you the peace of mind knowing the unit is save around water and will not endanger human life.
This clamp light is the new lighting range with optimal lighting with low energy consumption. Featuring a wide spectrum of light specifically needed for marine corals, without causing any harm through heat or harmful energies such as Ultra-violet and Infra-red. Each LED lasts for up to 50,000 hours of usage sustaining low maintenance, This clamp light LED is engineered for energy efficient lighting.
Features:
* Clamp on aquarium LED Light.
* Complete with electronic dimmer/timer.
* External ON/OFF switch.
* Sleek corrosion resistant ABS plastic & aluminium.
* Aluminium Heat-sink top for heat escape.
* 2 built in fans for efficient cooling.
Lamp head Dimension: L334xW122xH75 (thickness)
Max gooseneck Length: 392
12 Month warranty.
http://www.guppysaquariumproducts.com.a ... t_248.html
Andries
Re: Introducing Brand New 72W clip on LED lights
Postby ahpat » Tue 28 Feb, 2012 5:42 pm
Hi would this light be enough to supplement a 3.2ft x 2 x 2 reef tank which already has a Metal Halide?
ahpat
Postby Andries » Tue 28 Feb, 2012 6:23 pm
ahpat wrote:Hi would this light be enough to supplement a 3.2ft x 2 x 2 reef tank which already has a Metal Halide?
Yes, I think you will not use the m/h when you put this over the aquarium, it is really bright.
Andries
Postby Fiddy5 » Sun 29 Apr, 2012 10:18 pm
How much?
Fiddy5
Postby Andries » Sun 29 Apr, 2012 10:33 pm
Andries
Postby pleco4me » Sat 12 May, 2012 2:42 pm
Anyone purchased one of these yet? Would love to hear some feedback/reviews.
My issue is that my tank has bracing about 6cm wide around the top, so I would most likely need to make a bracket of some sort to support the light.
pleco4me
Postby webber555 » Mon 28 May, 2012 7:26 am
I'm interested in one of these as well - do the white/blue have separate switches to setup 2 timers? Or is it programmable somehow?
webber555
Postby Andries » Wed 25 Jul, 2012 8:40 am
bodyboardingbum wrote:Anyone have any experience with these? Considering a pair for a 3ft shallow, suggestions? Handle SPS, Nems and Clams?
They are on Deal of the day today :thumbsup: so today will be the best price you will ever see them. They will suport any coral in your 3ft tank.
Andries
Postby Andries » Wed 25 Jul, 2012 1:15 pm
bodyboardingbum wrote:Can you offer a return guarantee if they don't support SPS?
The lights WILL support it, the problem might be with your water quality.
Andries
