Cree Controll Marine LED Light Fitting Now in Stock
Postby Andries » Thu 16 Feb, 2012 12:46 am
We now stock the newest Cree Controll Marine LED Light Fitting
We have them i 2ft, 3ft and 4ft.
This is a brand new Intelligent Marine Aquarium light fitting using the finest Cree LED's with a wide light spectrum.
This light comes complete with 4 different colour ratio (Spectrum) LEDS to bring out the best in your coral, fish and infinite colour choice to suit your unique taste.
The light unit comes with timer built in to program your own lighting regime, complete with sunrise and sunset, Moon Lights with built in lunar program if you choose to use it or set it yourself.
Every channel (4 colour ratios) are individually dimmable via the on-board timer or via the included wireless remote control.
Built in Timer has 90day built in backup and will not lose your settings with a power outage.
Light fitting comes with complete ajustable hang kit included
Light fitting comes with fully adjustable removable brackets included as standard.
Also comes with five pre-programed lighting programs, Normal, Spring, Summer, Autumn and Winter
As an added bonus the power pack also comes with a inbuilt dimmer if for some reason you need to dim the lights but don’t want to go into the main program.
2Ft Information
Total led quantity:40 pcs
Colour ratio :
White 8300k 20pcs CREE diodes
Blue 460nm 12pcs CREE diodes
Royal blue 455nm 5pcs CREE diodes
Purple 427nm 3pcs Bridge-lux diodes
Beam Angle is 90 degree
Power:64x3watt diodes
Weight 6.5kg
Voltage 100 to 240VAC
Fan start-up temperature 45deg.C
Ideal for a 2ft x 600 marine aquarium.
http://www.guppysaquariumproducts.com.a ... _2583.html
3Ft Information
Total led quantity:64 pcs
Colour ratio :
White 8300k 32pcs CREE diodes
Blue 460nm 18pcs CREE diodes
Royal blue 455nm 8pcs CREE diodes
Purple 427nm 6pcs Bridge-lux diodes
Weight 8.5kg
Ideal for a 3ft x 600 marine aquarium.
http://www.guppysaquariumproducts.com.a ... _2582.html
4Ft Information
Total led quantity:88 pcs
Colour ratio :
White 8300k 48pcs CREE diodes
Blue 460nm 24pcs CREE diodes
Purple 427nm 8pcs Bridge-lux diodes
Power:88x3watt diodes
Weight 8.5kg
Ideal for a 4ft x 600 marine aquarium.
http://www.guppysaquariumproducts.com.a ... _2584.html
Andries
