New PO4x4 Now in stock
Postby Andries » Sat 10 Dec, 2011 5:59 pm
We now have the NEW PO4x4 in stock, this product is made by the same manufacturers of NP reducing pellets.
http://www.guppysaquariumproducts.com.a ... _2465.html
http://www.guppysaquariumproducts.com.a ... _2466.html
PO4x4 Phosphate Remover
PO4X4 Phosphate Remover is a unique chemical engineered polymer based mini pellets that will specifically remove phosphate approximately 4 times more efficient then most GFOs. The PO4X4 polymer is bound to very pure FeOH2. Both the polymer as well as the Iron molecules are able to bind PO4 and by combining these we increased the binding effiency. In addition,PO4X4 contains only Ironhydroxide, normal GFOs consist of a mixture of ironhydroxide as well as ironoxide and only the first form can bind phosphates. This means that PO4X4 with its higher content of Ironhydroxide can bind much more PO4 then your average GFOs can.
500 ml will remove 3 ppm of phosphate and silicate from roughly 16.000 liter of fresh water or 8.000 liter of marine water. Use fluidized filter systems for optimal results, a canister filter can also be used. Do not overdose ! Rapid changes in phosphate can negatively affect your animals. Use small amounts of PO4X4 to gradually lower the phosphate levels in your aquarium. Replace or regenerate (see PO-X4 regeneration salt) your pellets when phosphate levels start to increase again.
My nitrate and phosphate levels are close to zero, but algae is growing ! Sounds familiar ?
Maintaining the levels of waste products low while feeding your animals on a regular basis is essential for keeping invertebrates and fish in good health. In microbial well balanced aquaria, the two major pollutants are nitrates and phosphates. With current use of NP-Reducing BioPellets, it has become very easy to maintain nitrates and phosphate levels close to zero, however, in most tanks there is still a surplus of phosphates. Phosphate levels exceeding 0.03 ppm will negatively affect coral growth and higher levels will also negatively influence the health of your fish. In addition, high phosphate levels enhance the growth of annoying algae and cyanobacteria. Most of current phosphate reducing products are based on granular ferric hydroxide and leak iron-ions into your tank, which is enhancing algae growth and inhibiting coral growth and have a tendency to start clumping together, thus reducing its effectiveness.
Almost every other iron based GFO is releasing iron-ions to the water up to 10 times more than natural seawater levels. This is tested and confirmed at the university of Wageningen, Holland. The tests were done with a inductively coupled plasma mass spectrometer.
Our novel PO4X4 Phosphate Remover is a unique chemical engineered polymer based mini pellets that does not have these down sides. In other words, there is hardly any leaking of Iron-ions, the pellets do not clump together and can be readily used in fluidized filters. They have a very high surface area and can absorb approximately 4 times more phosphate then most other phosphate removing products. 250 ml will remove 3 ppm of phosphate and silicate from roughly 8.000 liter of fresh water or 4.000 liter of marine water. Do not overdose! Rapid changes in phosphate can negatively affect your animals. Use small amounts of PO4X4 to gradually lower the phosphate levels in your aquarium.
PO4X4 is now availeble in 250ml and 500ml.
Andries
