hammer fragging
Discussion on breeding & propagating marine fish, corals & other species.
Moderators: Moderators, Mod: Propagation & Breeding
hammer fragging
Postby elliven » Fri 12 Sep, 2014 9:04 pm
Hey guys,
I've got a hammer that I want to frag but I want to do it from an individual polyp, I recall reading an article some time back saying that you would need at least 12 individual polyps or attempted frags to get one successful frag but cant remember where I read that.
So basically I understand that I cut one polyp and glue to a plug but I'm not sure if there is a particular place on the polyp that should be cut or angles and such, so if anyone has any tips, they would be appreciated.
"Common sense is not so common."
Voltaire, Dictionnaire Philosophique (1764)
elliven
Re: hammer fragging
Postby Morphology » Wed 05 Nov, 2014 7:23 pm
What sort of things are you fragging? Photos of what you'd like to frag would help :)
Morphology
Re: hammer fragging
Postby chrismelb » Wed 12 Nov, 2014 2:06 pm
Recently fragged a pup from my Reverse tip, which was growing at the base. I simply used strong scissors and successfully managed to remove pup. Probably the smallest frag I have made.
You can see parent colony and removed pup in my frag tank in the bottom right.
Here is close up of the frag a few days later. Cute huh
chrismelb
Re: hammer fragging
Postby Jrossi86 » Wed 12 Nov, 2014 11:04 pm
That's cool nice work, I have tried probably 4 times with my reverse hammer and every time i seam to fail
- Jake
- Running a modified AR300 setup.
Jrossi86
Re: hammer fragging
Postby elliven » Sat 15 Nov, 2014 10:06 am
That's pretty cool, I've never noticed any pups growing off mine.
I tried to frag mine from a polyp, turns out they don't like being cut and retract completely into the skeleton everytime the scissors go near a polyp, who knew?! I managed one cut from the top of the polyp, it dissolved the next day. I might try again if I can cut quickly enough to get a longer polyp or more than one.
elliven
Re: hammer fragging
Postby oceanarium » Sat 15 Nov, 2014 10:35 am
Do you mean tentacle a off a polyp rather than the whole polyp?
I don't think that will work, if doing part polyps you need to take some skeletal with the flesh.
oceanarium
Re: hammer fragging
Postby elliven » Sat 15 Nov, 2014 10:52 am
I was under the impression that each tentacle was an individual polyp, evidently not! Explains why I have only been successful when there has been some skeletal matter in the fragment.
elliven
Return to Propagation & Breeding
