Few noob questions on fragging
PostPosted: Mon 02 Jun, 2014 2:30 pm
by matts20891
Am hoping to attempt to frag my duncan next weekend, fragging is something I've never tried before. Just have a few quick questions for clarification - they may be a bit simple but all responses are welcome.
1) what sort of tool can/should I use? I have access to a jigsaw but was thinking about buying a dremel anyway, they seem to be the preferred choice for this operation.
2) what dremel do I buy? Does it need any special features or can I just buy the cheapest one I find? I'm guessing just avoid any water hitting the tool. I think bunnings has them for just under $100.. If anyone knows where the best place to buy a dremel please let me know!
3) should I be dipping the frags in a revive solution? I did read that with clean cuts and a healthy specimen that this doesn't add much value to the operation, but i think ill do it anyway (at least on my first attempt)
4) if dipping, is 5 minutes the usual time?
5) lastly and possibly the most simple question, I'm assuming you shouldn't put the water that was mixed with revive back into the tank?
I know for most people it's a pretty easy procedure, but being my first time I wanted to make sure I do things right, rather than regret it later. If anyone else has any advice/tips it would be much appreciated
Re: Few noob questions on fragging
PostPosted: Mon 02 Jun, 2014 3:12 pm
by Jlangtree
1. Dremel is fine, usually a small wet band-saw with a fine blade is best.
2. Grab an "El' Cheapo" brand though if your not going to be using it much.
3. Never hurts to dip :-)
4. 5 minutes is all I dip frags for.
5. Never put that water back into your tank.
PostPosted: Mon 02 Jun, 2014 3:44 pm
by matts20891
Thanks for the reply. Is that about the price you would expect to pay for a cheapie? How much is a quality dremel worth?
PostPosted: Mon 02 Jun, 2014 5:06 pm
by rgv4play
expect to have change from $50 for a cheapie with a good range of attachments for cutting, no need to go a dremel branded unit, alternatively a small fine toothed hand saw would suffice aswell.
PostPosted: Mon 02 Jun, 2014 5:13 pm
by matts20891
Cool. Sorry to keep asking questions, but where do I find cheapies? I've only checked out Bunnings and mitre 10, where else would sell them?
PostPosted: Mon 02 Jun, 2014 5:29 pm
by matts20891
Scratch that last post, just answered my own question
by chromus
Cheapie Dremel knockoffs are almost as good, but definitely get the REAL dremel tile cutting blade, there is no comparison and the fitting fits most cheapie units.
